Weird Problem
Today I was driving and I noticed my check engine light came on......so I went to autozone they got a machine that scans your car and finds out the problem.......and it said something like "high flow air injector flow incorrect"......does anyone have any idea what I am talking about......I always put the highest gas grade for my car, I give it a synthetic oil change.
RE: Weird Problem
Sounds like the error I got a while back. If it's your long term fuel trim I'd bet it's either your O2 sensors or your mass airflow sensor. How many miles, and have you had the O2 sensors replaced? I replaced both O2 sensors and the MAS at around 100K miles because I had a air fuel mixture error.
RE: Weird Problem
NO but the guy said that thats wat it might be, the o2 sensors that is.......and how much are the o2 sensors and u think itll fix my problem.
RE: Weird Problem
o2 sensors run about 100 bucks each.
RE: Weird Problem
Do you guys think thats wat the problem is?
RE: Weird Problem
is your car running ok?
RE: Weird Problem
Yeah the car is running fine
RE: Weird Problem
so you guys think if i replace my o2 sensors that my problem will be fixed
