Weird Stalling
Old Mar 9, 2007 | 03:46 PM
GarbearA4's Avatar
Default Weird Stalling
Yesterday when I turned on my car the RPMs started idling around 1300. That is unusually high for my car. I let the car warm up for about 5mins before driving. I drove for about 15mins, then I stopped at a redlight. The RPMs suddenly dropped to 0 and my car shutoff. I wasn't in gear at all. I turned on my car again, and a good 5 seconds later my car did the same thing. I turned on my car once again and pulled into a parking lot and had my car towed. I haven't received a call to see what the problem is yet. I am just wondering if any of you guys have an idea of what the problem is. My car is a '97 A4 2.8. Theres about 97K miles on it, and I just had the clutch replaced 2 months ago. I was going to get my timing belt replaced within the next 2 weeks also. Thanks in advance.
Old Mar 9, 2007 | 03:55 PM
onepoint8tee's Avatar
Default RE: Weird Stalling
Could be a few different things like ects, maf, vac leak, etc. Im thinking vac leak though.
Old Mar 9, 2007 | 04:00 PM
GarbearA4's Avatar
Is that a big time repair? Like time/money? And I didn't take it to an Audi dealership to fix. For a timing belt they said around $1700 total. Thats a bit insane. And thanks Onepoint.
Old Mar 9, 2007 | 04:03 PM
techbod's Avatar
it could be anything without fault codes but im guessing it a vacuum pipe leak or one has came off
Old Mar 9, 2007 | 04:06 PM
timing belt can be done by a local shop/not the dealer for around $600 usually. But id do it myself (and have) and its not hard, just takes time, tools, and a DIY article which can be found lots of places. It would cost you about $350 or so to do it yourself. BIG SAVINGS! (that includes, T belt, all other belts, water pump, t-stat, and the updated tensioner + roller. I got mine from www.ecstuning.com and you might be able to peice the kit together for less from www.purems.com
Old Mar 9, 2007 | 04:15 PM
GarbearA4's Avatar
Yea I've looked at the DIY and was going to try it because my one friend goes to school for Audi after graduating from a Tech school. But, the major factor that made me not want to do it is time. I drive everyday for class and work. I mean I could try on Spring Break, but it would take a good bit of time. Thanks again guys. I just hope this doesn't burn a hole in my wallet. And the place I took my car to said they woulddo the belt for $660, which is a whole ton better then $1700.
Old Mar 9, 2007 | 04:23 PM
Right, but for $660 are they doing the waterpump, tstat, tensioner, roller, and other belts?? It doesnt take THAT much time to DIY.. A good chunk of a day,8 or so hours for a first timer, but damn, is your schedule really that tight that you wouldnt have time on a weekend or something?
Old Mar 9, 2007 | 04:32 PM
GarbearA4's Avatar
I might give it a try. My schedule is pretty rediculous. 2 jobs and 5 classes. Hmm...I will ask my friends if they'll help me out on it since you said it would only take a full day. Thanks again
DavidWNicholls
Apr 4, 2013 01:20 AM
Myst420
Jan 18, 2011 09:15 AM
ajkst1
Feb 28, 2009 11:58 AM
TankA4B5
May 9, 2007 07:57 PM
ByPopularDemand
Oct 25, 2005 12:20 AM
