Well i think im gonna do it (about 80% sure)
Old Jun 11, 2007 | 07:26 PM
Karl's Avatar
Default RE: Well i think im gonna do it (about 80% sure)
No that is a intercooler mister..
this actually puts the mixture in your engine
Old Jun 11, 2007 | 07:31 PM
Lopster99's Avatar
Im gonna go look it up.. it sounds pretty cool
Doesn't it harm any of the internals
Karl's Avatar
Boost Cooler Stage-2 (for all factory ECUs)
1. Pump is upgraded to 150psi for superior atomization.
2. Includes either a MAF or MAP-based Variable Controller that varies the quantity injected vs. air flow for the smoothest power curve possible.
(Choose MAP version for engines without MAF sensor.)
High-Boost MAP Controller upgrade (25psi+)
• Upgrades Stage I or II Kits for use with more than 25psi boost
• Controls Injection Pressure as a function of Boost
• Fully Integrated Boost Sensor 0 to 100psi
• 0-5 Volt Boost Signal Output
• 1.5% Maximum Error over 0 Degrees to 85 Degrees Celcius
• Potted Electronics and Rugged Design for Under Hood Applications
• Easy Adjustment and Setup
• Electronic Resetable Fuse and Transient Voltage Suppression to Protect Controller.
Old Jun 11, 2007 | 07:34 PM
koenigar17's Avatar
I think it is time that I add that my friend with the EVO blew his engine last week. He only had the methane for 7 months before he blew it... and he only drove it about 10 days all winter [wintet = 5mo in wisconsin] Although he wasnt exactly easy on the car.
Old Jun 11, 2007 | 07:36 PM
Karl's Avatar
thats too bad for him.. was he running lean??
Thankgod for VAG and logging
If done right, this is a safe mod, that will prevent you from blowing your engine.. you just have to know what your doing
Old Jun 11, 2007 | 07:46 PM
Jeff's Avatar
Zombie Defense Force
thats going to be so much fun. if i stop buying stupid things like guns and beer then i would get that on my car
Old Jun 11, 2007 | 07:49 PM
koenigar17's Avatar
Yup. Ran lean.... got a little hot and froze 'er right up. It was really sad because it was a 12 second car that he let me track from time to time.
Old Jun 11, 2007 | 07:58 PM
  #18
Karl's Avatar
ORIGINAL: Jeff
yeah i know what you mean.. too much booze in my budget. i need to cut back
Old Jun 12, 2007 | 01:35 AM
  #19
kraylon's Avatar
im am very inested in the water meth injection i looked it up a while ago but never though much about it how much was the kit and where did you find it??
you should do a install write up
Old Jun 12, 2007 | 01:55 AM
  #20
Jeff's Avatar
you can get a meth/alky kit for 500. depends on the pump and how many safety features you get. whats cool about snowmeth is they have a low level warning light. most people blow their motors when the meth runs out and they continue to run. then they detonate and blow the motor. surpriseingly not many compaines have failsafes
