AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   What coolant are you using? (https://www.audiforums.com/forum/audi-a4-8/what-coolant-you-using-34166/)
a4sport Jun 15, 2006 12:44 AM
If you aren't using Audi coolant on your A4, what coolant are you using.
Reason I ask, is because I have a coolant leak on my upper radiator hose on my b6. I have had to buy 2 gallons of Audi G12 coolant now. I just need to get the hose from Audi, I know, but it's on its' way.
Is it ok to add another coolant to the G12/Water mix that is already in there to top off the reservoir tank?
Trey25 Jun 15, 2006 12:47 AM
RE: What coolant are you using?
I don't see why it would make difference what coolant your using, in the end coolant is coolant regardless of brand.
wemmington Jun 15, 2006 02:55 AM
After I did my timing belt i used water only(no cooant) for a few days with no issues and have since put in generic coolant(auto zone) I havent noticed any difference in temp between just water, generic or audi coolant. Maybe longterm its slighlty better. idunno
" Is it ok to add another coolant to the G12/Water mix that is already in there to top off the reservoir tank?"
If its not very low im sure u can just add water and be fine. I think the mixture should be 30-50% water/coolant but im not sure if u can mix coolants but prolly so.
PKSJeter Jun 15, 2006 03:36 PM
i'm pretty sure you're not supposed to mix the g12 coolant with any other kind of coolant. at least thats what the bentley manual says. in fact i believe the g12 changes color from red to brown when another kind of coolant is mixed with it. mixing it might not do anything tho and they're just anal.
acetrebo Jun 15, 2006 03:51 PM
Use a 50/50 mix of G12 and distilled water.
Legaumais Jun 15, 2006 08:08 PM
Hi,
not to more use not G12. Use G12plus which is "filled-for-live" solution.
http://img226.imageshack.us/img226/4794/g12plus0gm.gif
http://img48.imageshack.us/img48/284...uctions8ge.gif
TomRitt Jun 15, 2006 08:19 PM
Coolant is actualy not coolant regardless of brand. I have seen ppl mic regular green coolant with g12 and it turns into jelly... I use generic green stuff now
a4sport Jun 15, 2006 09:36 PM
I've just been getting sick of buying gallons of G12 for $20 a pop. I might see if I can just get a small bottle of G12+ and add it in there.
rbrtech Jun 15, 2006 09:41 PM
If you flush your suatem you can use your choice. Dex cool does work you just have to do a regular flush. There is some mix with anything coolants out there. But do not mix with g12. It does turn into jelly. Same as mixing the common green with dex cool its not a good outcome
a4sport Jun 16, 2006 12:12 AM
I will probably just stick with G12. Unless I have to take the radiator off again. Then I think I'm going with dex cool to save a few bucks.;)
