What do i need to fix this.......
Old Jan 25, 2007 | 04:38 AM
m5racer's Avatar
Default What do i need to fix this.......
ok for the last 2 week the engine light has been on. this code has come up before but no one ever told me what it was or whats broken. well yesterday it turned off without being cleared. today it came back on so i scaned my car and it gave me this code again. please could spme one tell me. i have tried clearing this twice beofre and it came back within a day or 2
1. what the code is refering to
2. what is broken
3. what parts do i need to fix
4. is is gonna be expensive, is anything happening to my car while this is boken
thank you in advance for your help.
Old Jan 25, 2007 | 04:54 AM
tractioncontrol's Avatar
Default RE: What do i need to fix this.......
It can be caused by a loose gas cap, bad gass cap, rust on the filler neck where the gas cap seats, bad vsv valves, leaks in the vaccume hoses running to the evap canister, or a bad evap canister. That is whyservice dept.say not to fill up with the engine running. The evap system on non intrusive systems test vaccume pressure after the car is shut off usually only a couple times a week, so if you got gas and later started the car and the engine light came on (even if it was a couple of days later) I would start with the gas cap and clear codes, if it comes on again check the vsv valves (usually one somewhere on or near the intake and the other on the evap canister) and clear codes and if it comes on again it would be the canister given there is no vaccumes leaks in those hoses. I would miagine you should be able to do an active test of the vsv valves and pump with the vag com tool but have never used on. If you can when the valves open and close during the test you should hear clicking indicating the valve is opening and closing. If there isn't an active test or you can't find it it can also be donewith a hand held vaccume testser.
