What is this noise?
Old Feb 14, 2006 | 10:30 PM
murphy_boy_2's Avatar
Default What is this noise?
I have just recently noticed that when I drive my b5 1998 A4 slow and have the window down, I can hear a squeek on the right side of the car. I think its something with the wheels. Could that be wheel bearings or something else? Any thoughts are welcome. Thanks
Old Feb 14, 2006 | 11:05 PM
avanttripleloop's Avatar
Default RE: What is this noise?
it might just be brake pads,try stepping lightly on brakes when driving and see if noise disappears.
Old Feb 14, 2006 | 11:15 PM
Yuikio's Avatar
Could be control arms. Mine squeak like a bastard in the rear. Is it continuous, or when you hit a road imperfection? Continous noise is most likely wheel bearings. If it squeaks when your suspension compresses or extends, it's likely control arms.
Old Feb 14, 2006 | 11:56 PM
juice88's Avatar
or cv joints. turn the wheel completely to the side that makes the noise and check behind the to check and see if the rubber boot, piece of rubber connected to the back of rotor to see if its ripped and there is grease and **** everywhere
Old Feb 14, 2006 | 11:59 PM
onepoint8tee's Avatar
ORIGINAL: juice88
There is no rubber boot connected to the back of the rotor... You mean the hub?
Old Feb 15, 2006 | 12:16 AM
StepUpProductions's Avatar
i have the same exact problem with my 2002 B6... it just squeaks when im not even on the brakes... it stops when i hit the brakes but i think my rotors are warped or need new pads so...
Old Feb 15, 2006 | 12:17 AM
juice88's Avatar
ORIGINAL: onepoint8tee
ORIGINAL: juice88
well technically thats what it is, behind it, i just didnt want to confuse him. yes i know thats not where its connected but hes a noob, like i can be sometimes right onepoint8tee?
Old Feb 16, 2006 | 10:19 PM
well the only time i notice it is when im going straight and slow and it sounds like its coming from the left side, not sure if its rear or front. I should probably figure that out.
Old Feb 16, 2006 | 10:33 PM
ORIGINAL: juice88
ORIGINAL: juice88
RIGHT! And thats very considerate of you to lower your level of intelect while communicating with noobs so that they can understand things. Your so courtious!
rahip4567
B8 Models
Nov 13, 2019 04:04 AM
kenman
Sep 12, 2012 02:34 PM
Schlampah
Jan 27, 2011 08:24 PM
tj19855
Dec 31, 2007 03:28 AM
tbrown
Sep 11, 2006 02:47 PM
