Wheel Bearing?
What does it sound like when your wheel bearings are going bad??? Can it mimic the sound of tread noise? I've noticed that for the past several months, I get a noise that starts around 20MPH, and increases directly relative to increase in speed. I first heard it when I had my winter tires on and just thought it was tread noise...but it remained after I put my summer tires on. I've read several posts...and suspected bearing problems seem to be noticed as "tread noise" at first. Any thoughts?
Thanks
Mickey
Thanks
Mickey
yes it starts out sounding like a bad tire, then well it just gets worse....
just keep in mind it is a replacment, they are non serviceable berings..
and if you can use audi parts, sometimes aftermarket parts just don't cut it.
E
E
thanks guys. would 71K be about the point where wheel bearings could/would go bad? Would a "good" test be to try and "wobble" the wheel? And if the wheel didn't "wobble"...could it still be the bearings?
~Mickey
~Mickey
The wobble test didn't work when mine went out. Go for a drive and make a few quick turns. If the sound goes away one direction and gets louder turning the other direction, it's probably the wheel bearing.
Yeah...I noticed the sound gets "deeper" when I turn to the right...but says at the same tone/pitch when I turn to the left. I guess my next questions are:
1: Get the wheel bearing from online or at the stealership?
2: Does anyone have a "ballpark" figure on what it should cost?
Thanks for everyone's help. As always, it's most appreciated.
~Mickey
~Mickey
ORIGINAL: Beer Mod
How many miles? It will sound like metal on metal with sand inbetween...........
