AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   WINDOW ISSUE (https://www.audiforums.com/forum/audi-a4-8/window-issue-19953/)
BLAZEDUPBEE Nov 17, 2005 01:13 PM
WINDOW ISSUE
I just got my front passenger side window replaced because it was broken.. Now when i open and close the window its a tad bit slower. I dont mind that as much as the fact when i close the window it closes all the way and then it automatically goes down like 2 inches. i have to hit the switch again right when its in the closed position for it not go down. any one know how i can fix this problem? if not im going back to glass place and complain..
huyaroo Nov 17, 2005 02:42 PM
RE: WINDOW ISSUE
Yeah this happened to me when someone broke the window on my accord. They might have damaged the motor somehow or there might be some glass stuck in the door that you don't know about. The place I went to didn't really clean the glass out completely.
nrosei4 Nov 17, 2005 02:48 PM
RE: WINDOW ISSUE
There is something causing the window to experience too much resistance as it moves. Hence, the slow movement. Then when it gets to the top of its travel, there is even more resistance - enough to cause the window to think there is an object in its travel.
Most likely, it's the alignment. Chances are, the motor is fine - it's not likely a motor becomes damaged easily.
BLAZEDUPBEE Nov 17, 2005 04:20 PM
RE: WINDOW ISSUE
i would think if the motor would be damaged i wouldnt be able to really operate the window.. but i already went by the place and told them they said just to bring it in tomorrow.
KelticSlob Nov 17, 2005 06:02 PM
RE: WINDOW ISSUE
I use Linux. No windows problems.
techbod Nov 17, 2005 06:05 PM
RE: WINDOW ISSUE
:D
BLAZEDUPBEE Nov 18, 2005 08:17 PM
RE: WINDOW ISSUE
UPDATE.. I went back to the place i got the window replaced at and they fixed it so it goes up and down quick and smooth. BUT when i close the window itll go up and then go down about 2 inches. any body know why its doing this?
techbod Nov 18, 2005 08:26 PM
RE: WINDOW ISSUE
press the window button and keep it pressed in till its closed then do the same to open it this resets the system, if that doesnt work it needs to be synchronized with the remote key fob
