window problems
Old May 4, 2005 | 12:51 AM
auDi1.8TQ's Avatar
Default window problems
My driver side window is acting weird ever since i got my a4. I don't even want to open it cause of this, well, when i open the window and try to close it back, it just goes half way and automatically stop and go back down...until i keep on doing this 20+ times then it works.....i was just wondering what is causing this? and how can i fix it?
Old May 4, 2005 | 02:33 AM
auDi1.8TQ's Avatar
Default RE: window problems
Can anyone help me out?
Old May 4, 2005 | 02:45 AM
BFlan2001's Avatar
sounds like you need a new switch. you can install it yourself, and the part number should be stamped on your current switch...removing the door panel is pretty simple, it's just a few phillips-head screws
Old May 4, 2005 | 02:52 AM
black991.8tq's Avatar
no its not the switch, my ride dose it also the window dose not go up correctly and about half way it starts to lean the wrong way then goes down. dose it work well when its wet. this is a good question and i would also know if anyone knows how to fix
Old May 4, 2005 | 02:54 AM
BFlan2001's Avatar
sorry, i'm stumped
Old May 4, 2005 | 04:21 PM
auDi1.8TQ's Avatar
yea, it does lean a little thats when i try using my hand to help it go up....and it still stop and go back down....please help me out...thanks
Old May 4, 2005 | 04:27 PM
hb972.8q's Avatar
i know our windows have safty feature. if something gets stuck in the window if automaticly goes down. mabe there is something on the track or on the where the glass slides into.
hope this helps
Old May 4, 2005 | 08:18 PM
auDi1.8TQ's Avatar
thanks, let me check it out see to see if there is any stuck...its just a few philip screws right?
Old May 14, 2005 | 09:20 PM
auDi1.8TQ's Avatar
well...i finally check my window, but i cant seem to find out why its acting up...anybody has any more suggestions?
Old May 14, 2005 | 10:16 PM
Shaunp05's Avatar
Check to see if it is running in the track smoothly up and down
and all the bolts and riverts are in place,
Tap the switch while u putting it up and the motor
there could be an internal short cozing it to reopen the window
you can test that with a Sonic Tester if you have one ...
Hope this helps
