WTF...
Old Jul 22, 2007 | 09:20 PM
onepoint8tee's Avatar
Default WTF...
17743 - Engine Torque Monitor 2: Control Limit Exceeded
P1335 - 35-10 - - - Intermittent
The firstfew posts in thisthread say it all:
http://forums.vwvortex.com/zerothrea...&id=359613
I get this symptom even with the mbc turned all the way down, yet has only started happening since I installed the mbc...
Old Jul 22, 2007 | 10:18 PM
TeeterTawter's Avatar
Default RE: WTF...
does this codeonlyapply on an auto/tip car?
I have the same mbc you have on a 2000 1.8T as well, just i am standard and quattro and just went out and scanned but no codes.
Old Jul 22, 2007 | 10:34 PM
Default RE: WTF...
Im sure it applies to any car as it is an engine fault code and is not a tranny fault code.
Old Jul 22, 2007 | 10:44 PM
auditech79's Avatar
Default RE: WTF...
I only see these fault codes when the wastegates get stuck closed.
So far as i know its just a reminder that the engine is seeing too much pressure/air flow
Old Jul 22, 2007 | 10:54 PM
Default RE: WTF...
Ya well its gotta be related to the mbc, thats all I know. Andthat is whats causing the throtle cut/epc light. Im going to look for another N75H. I never had problems with that. (I broke it while removing it once.)
Old Jul 23, 2007 | 08:17 PM
Default RE: WTF...
Issue resolved....
So, apparently I wasnt turning the dial on the mbc hard enough. Heres how it goes... No matter how much open or shut the mbc was between what felt like fully turned down, and fully turned up- theres a difference of 2 or 3 psi. Its consistanly been boosting at about 20 psi. The main difference beetween fully open/shut is how FAST it reaches full boost. So I had it almost fully open at times because max boost was at a safe limit, and boost came on soon/fast/STRONG (even for a k03.) I turned it as hard as i could just now FULLY down and got the **** to turn about a half revolution. Now, boost ismore smoothly delivered throughout the power band, 18psi max, no throtle cut, and my exhaust note for some reason is noticeably deeper . So there is a key difference between tightly closed/turned down, andreally fuckingtightly closed/turned down. Time will tell though, I only took it on a 20 min. drive trying to get it to duplicate the symptoms (throtle cut.)
Just thought Id share because I think a couple other members got the same mbc, maybe mine is just a bitch like that.
Old Jul 23, 2007 | 10:38 PM
wood_e's Avatar
Default RE: WTF...
easy fix?
WTFOMGBBQ!!@!#45312
Old Jul 23, 2007 | 10:42 PM
cincyTT's Avatar
I'm make believe
Default RE: WTF...
thats it, blame the mbc on human error (humor again) <- pointed that out for no mistakes this time
Old Jul 23, 2007 | 10:50 PM
Default RE: WTF...
You didnt have anything like I described with the use of this mbc on your bros passat right?
Old Jul 23, 2007 | 11:14 PM
cincyTT's Avatar
I'm make believe
Default RE: WTF...
worked fine out of the box. Took some time to get it set so it wasnt boosting over 20psi, but he is at like 3 or 4 clicks and 17psi
