Yellow Xeon
Old Nov 20, 2004 | 10:05 AM
fabricator's Avatar
Default Yellow Xeon
My right headlight is kinda yellow. It seems to be very close in brightness to the left one. For what these cost I figure I'll ask around first.
Do xeons have voltage/ballast adjustments or is this plainly a bulb going bad?
P.S. Wife wants to take car home for Thanksgiving! Don't know if I can handle it.
Old Nov 20, 2004 | 12:25 PM
CRAZYHAWK's Avatar
Default RE: Yellow Xeon
I don't believe there is a voltage adjustment.
Old Nov 20, 2004 | 05:39 PM
A4 R6 wku's Avatar
hey fabricator, what do you fabricate?
Old Nov 20, 2004 | 08:26 PM
Jestnomen's Avatar
6th Gear
Dont know what to tell you man, there is nothing you can do other than by new bulbs. You can get new XENON (not xeon) bulbs on Ebay for around 60 bucks a pair. Look for a heat color of greater than 4300k. The higher the number the bluer the color. Don't go above 6k as you will loose light output and have really blue ricer bulbs.
Old Nov 21, 2004 | 12:56 AM
SlimChriz's Avatar
the brighter bulb was probly replace already.. as bulbs get older they get dimmer
Old Nov 21, 2004 | 10:32 AM
fabricator's Avatar
ORIGINAL: A4 R6 wku
Current project is a Formula One simulator.
Thanks to all for the info.
Old Nov 21, 2004 | 10:36 AM
fabricator's Avatar
ORIGINAL: SlimChriz
Suppose I better pull the good one for a part number otherwise the color might not match?
Old Nov 21, 2004 | 11:22 AM
Jestnomen's Avatar
6th Gear
The color probalby won't match anyways, as chris said as the bulbs get older they change color. Especially xenon bulbs. If you buy them at the dealer, you're going to get raped on the price.
Old Nov 21, 2004 | 02:01 PM
fabricator's Avatar
Found some Phillips replacements on ebay for $68 a pair. Is this price too good to be true? Why are the prices so much higher at the parts houses.
Old Nov 21, 2004 | 02:46 PM
Jestnomen's Avatar
6th Gear
They are so expensive at the store because there is very little competition (not like napa, or autozone sells them). On ebay the sellers buy them in bulk and can sell dirt cheap. Philips are the factory brand.
Make sure you buy the D2S (for projectors), not the D2R (for reflector housings). Which color bulb are you looking to buy?
