Audi A5 This sleek mid-sized A5 coupe offers performance with a roomy interior.
AUdio and MMI
Old Feb 10, 2011 | 05:00 PM
A5Pete's Avatar
Default AUdio and MMI
Not a big deal but whenever I put the key in to check oil level (MMI) or move wipers to the Maintenance position, the audio (radio, sat, or whatever was on last) comes on. I then have to mute it (touch on/off **** w/out holding it) or go ahead and listen to whatever is on. Is there a way to keep the audio off (I always turn everything off when I shut the car down) and still check the MMI?
This happens either while starting the car or just in the auxiliary position (car on but engine not started).
Old Mar 23, 2011 | 01:05 PM
jessy's Avatar
hi
you have to check your engine of car.
Old Mar 25, 2011 | 04:53 PM
A5Pete's Avatar
Not sure I understand what you are telling me to check.
Old Jun 9, 2011 | 05:41 PM
qblue's Avatar
Default MMI and audio
To answer your question: NO
Unless you can reprogram the MMI it will come on as a 'convenience' to you, whether the key is in w/ alternator mode on with engine on it will always resume where you left it. You can even turn it on without the key( a retrospective look to the old AUDIS and German cars), but at least it will shut off on a timer or you can put the key in an remove it to shut off the radio. Not like my old A8, where if you turn the radio on w/o the key in ignition, it will stay on. And ruin your battery too.
Its not that convenient, but it does save your battery. They should install an on/off switch.
guest196826
Nov 25, 2011 07:36 PM
huggybearv1
Jul 3, 2011 07:22 PM
ArchieA4
Jun 24, 2011 05:21 AM
Quattro_A484
Nov 19, 2006 10:19 PM
smokeU
Aug 28, 2006 02:11 PM
