Thanksgiving Catastrophe
I have a 2011 A5, So Driving from Savannah, GA to Nashville, TN and just had my 45k maintenance done last friday with new Ignition coals. I get to Chattanooga, TN and switch over to manual shifting and accelerate. No warning lights or anything and all of a sudden as I am accelerating the engine starts stuttering car starts shaking and then poof, I am blowing white smoke out the exhaust like a snow storm. Anyways end state is had it towed to Nashville Audi and the Fuel pump went out on me.
Anyone else have this happen with this little mileage?
You sure they said fuel pump? Not sure how a pump could fail and cause white smoke...................Transfer pump (in tank) or high pressure (on engine)?
White smoke generally indicates coolant burning OR raw fuel from (for example) a stuck open injector. Did they maybe say fuel INJECTOR and is it a 2.0T? When I was an Audi tech, recall replacing a lot of injectors in those for sticking wide open, dumping raw fuel and generally causing all sorts of grief for the customer. This was on both Audi and VW 2.0T. Usually it would be as you describe, everything is fine and then POOF dead miss, white smoke, raw fuel dripping from the t-pipes.
I'm sure they will do this but make sure they also changed the engine oil after repair. With and injector stuck open (if that's what happened) some of the fuel will make it's way past the rings into the crankcase and dilute the oil.
