01 2.7T Squeaky windows and steering wheel
Everytime i put the windows down they ALL squeak. Also, when I turn the steering wheel it squeaks as well. Has anyone else had this happen, and if so, how did you get rid of that dang sound!?
Daniel
Daniel
RE: 01 2.7T Squeaky windows and steering wheel
Squeaky window is a common problem. Get some good rubber protectant (303 Aerospace is my choice -- virtually impossible to find in stores but you can order online), apply it to a cloth, and run that along the rubber seals that make contact with the window. You'll have to do this repeatedly over time to make the problem go away. Some people use silicone spray but that is not good for rubber (nor is Armorall) so I've shyed away from that solution.
A search might revel some info about the steering wheel squeaking on you. Not sure what's up there.
