02 a6 brake light issues
Old Jun 5, 2015 | 02:01 AM
tdoggy's Avatar
Default 02 a6 brake light issues
i have the annoying yellow brake light coming up on the dash i just bought new bulbs and installed but the brake light is still out its only the left side too right side works
Old Jun 5, 2015 | 08:43 AM
Nebuchadnezzar's Avatar
I would try switching the two new lights around first. You never know, maybe one of the new ones was actually defective. Stranger things have happened. After ruling that out, you will have to see if there is voltage reaching the socket using a DVOM and work your way back to the brake light switch / fuse.
I did some work on a Land Rover once and it turned out the prongs in the socket had some much corrosion on them (The lens had a small crack that allowed moisture in) from the elements that it no longer was conducting the current. This could be your case as well.
caloesch29
Apr 23, 2014 10:48 AM
blanthony
Mar 25, 2006 01:18 PM
thintzen
May 13, 2005 11:44 PM
