02 Sensors
Agree with M5S5 - unless you had a turbo bust loose and drench the entire exhaust with oil, I can't see all 4 going at once. They may be OK, but something else is causing them to throw codes. Get all the info you can from a VAG-COM and post it here. Could even be the heater line to the sensors has broken/quit/??? - only the codes will tell us...
Jim
Jim
2000 A6 O2 Codes
All,
Here are the O2 codes I have.
16543- O2 Sensor Bank 2 sensor 2 response too slow P0159 intermittent
17585- Bank 2 O2 sensor correction behind catalyst control limit reached P1177
16523- O2 sensor bank 1 sensor 2 response too slow P0139 intermittent
17584- Bank 1 O2 sensor correction behind catalyst control limit reached P1176
Both banks.
Both banks.
