03 A6 Timing Belt
#21
Ouch, that's not a good thing.
If you set your cam lockers correctly I can't see the cams moving. The question is then what way the crank turned to arrive at its current location. Given how far it is off of TDC, I really can't venture a guess. In theory you should be able to fix this issue by rotating the crank in the opposite direction in which it was moved to TDC while keeping the cams locked in place (Assuming the only the crank moved.)
Remember when doing timing that if you marked your cams and crank you won't see it line up until two full revolutions. Once for compression and once for exhaust. Marking the cam sprockets and the crank sprocket in the future could save you some trouble, as well as anyone reading this thread in the future.
#22
I believe what happened is this. When I was loosening the 4 camshaft bolts with old timing belt on, the last bolt on one of the camshaft (after loosining the first three) rotated the crank counter clockwise. Since the camshaft has a quite bigger diameter than crank it was reflected more like 30-40 degrees on crank. I believe I need to loosen the all four camshaft bolts and rotate the crank clockwise till it gets back to the line. Do you think so ?
#24
You can certainly try your method of fixing this issue by doing what you described, however I would caution you and tell you that you run the risk of ruining your engine if the crank and all cam sprockets did NOT move in tandem.
Your best bet would be to begin thinking about resetting the crank to TDC and then resetting the cams and valves to their appropriate orientation to reflect the position of each cylinder in order to avoid valve / piston collisions.
#25
I can see this happening. However, I believe the cam lock bars are to lock the cams in place so they don't move / pull the belt and cause exactly this problem with the engine's timing system. As such, I would suspect an issue with the cam(s) as well as the crank.
#28
This will not be the case for everyone with this issue. You managed to dodge a bullet (Assuming you have started the engine and it ran without any timing issues) Anyone reading this in the future should realize that this may vary from case to case and caution should be used when just rotating the crank when it's no longer at TDC after a timing belt job.
#29
Audiguruforyou
09-20-2011 01:31 AM
Jeffla
01-03-2010 04:43 AM
fritz
08-12-2007 02:55 PM
