1999 A6 2.8 repeated alternator failures
Old Nov 7, 2011 | 11:42 PM
ajc_616's Avatar
Default 1999 A6 2.8 repeated alternator failures
Need some help...i had an alternator fail in my 1999 a6 avant and i replaced it with a remaned unit and it ran fine for about a month and it failed. I replaced the alternator again which was under warranty. I also replaced the old battery along with the second alternator (it was quite old).It worked but this time only for a week or two. Im trying to find out what is causing this...is it a fault somewhere else besides the alternator, maybe in the wiring. i do see that there is only one wire running from the alternator which i believe goes to the voltmeter on the dash. It just doesn't make sense to me why 2 have failed within a month. could it be i got 2 bad remaned alternators? if anyone has any clue it would be great
Old Nov 8, 2011 | 08:50 PM
Jeffla's Avatar
I assume the new alternators are failing to charge? Is it possible that where ever you bought the reman alt from would let you switch brands?
Old Nov 9, 2011 | 10:26 AM
ajc_616's Avatar
Right now i have a Valeo alternator. So your saying that its possible to switch to Bosch with no problems? Is the Bosch a better alternator?
Old Nov 9, 2011 | 10:32 AM
ajc_616's Avatar
or do u mean switch to another reman company?
Old Dec 14, 2011 | 11:13 AM
RUFUSDESIGN's Avatar
Did you end up with any answers to this??? I am in the same situation right now. I also went with the valeo alternator and am thinking about going bosch, but don't want to spend more money if the alternator isn't the problem.
Old Dec 14, 2011 | 02:15 PM
NH_USA's Avatar
Repeated alternator failurs are usually due to a bad ground between the body and motor.
The strap might be tight but still making poor contact.
Remove the strap -both ends
Clean the surfaces - all four
Then put the strap back on.
Old Dec 14, 2011 | 07:25 PM
Where is there a grounding strap? There is only a wiring harness and a terminal B+.
Old Dec 15, 2011 | 03:11 PM
NH_USA's Avatar
Crawl under the car and look for the ground strap between the motor and frame.
It is usually on the right side near the front.
It most likely is a web style wire.
It certainly is not part of a harness.
blk99audi83
Jan 3, 2012 10:21 PM
TexasRho83
Jan 18, 2011 10:59 PM
romekss2
Sep 15, 2008 06:57 PM
romekss2
Sep 15, 2008 05:14 PM
hellrider
Sep 10, 2007 10:08 PM
