1999 a6 quattro windshield washer resevoir
i did a search and couldnt find any thing... how does it come out... im assuming i have to take the tire and the fender lining out to get to the other bolts. i have to repair mine before winter really starts to come
also sorry about the post before this i dunno wat happend
You have to jack up the left front of the car, remove the left front wheel, remove the front half of the wheel well inner liner, fold it back out of the way, remove three bolts from below and one from inside the engine compartment, then wiggle the reservoir out while removing the pumps. Then you have to carefully examine the reservoir to figure out which pump (or the level sensor) is leaking (follow the blue...), then figure out if it is the seal or the pump. It seems the pump tends to crack causing the leak.
Or, you can just fill it the the sensor, let a little leak out everytime, and carry a spare gallon of fluid eith you.
Bob
Bob
mcanedo92588
07-01-2013 11:27 PM
GoodLuckAudi
02-27-2007 07:33 AM
