2.7t timing belt, cam moved
pulled the cam locking too off and the passenger side cam moved... uhhhhh now what?
humm well reading this
URGENT: Doing timing belt job cam MOVED - AudiWorld Forums looks like its not a big thing |
Originally Posted by tadjo
(Post 1477327)
URGENT: Doing timing belt job cam MOVED - AudiWorld Forums looks like its not a big thing It's just valve spring pressure. Scared you didn't it? :p |
Nearly cried as I have several times during this. Got it all back together last night thought I was done. Added coolant and it started pouring out from behind the t-belt cover. Looks like I installed something wrong.
I’m not really a slouch as a mechanic but this by FAR has not been a money saving venture when lost time come into play. Think I’m 40+ hours in at this point and still have to take it all back apart and put it all back together. |
(Post 1477594)
I had put the t stat oring in the wrong spot, it SHOULD be block tstat oring, i had placed it block oring tstat.
hope that helps someone out there. what took me about 30 hours the first time only took about 5 the the second time. |
(Post 1477747)
hope that helps someone out there. what took me about 30 hours the first time only took about 5 the the second time. You should be an expert now and good to go! Congrats! |
