2000 with a 06 clip?
I have seen a post with some one on cardomains put a newer front clip on a 2000 how hard is it do I just get a hood and nose it looks like?
the c5 a6 has body kits that make it resemble I believe the c6 rs6. The pieces are from hoefle if I remember correctly.
Thanks Man I found it u spelt it right but it took forever to find one.
The bumper says it's for 2002-04 but it doesn't matter right? Long as it's the c5's I'm so stoked to of found it .
make sure you call the vendor and ask. I have the same question as mine is a 2001.
Jhoffman I just got off the phone with the vendor it bolts right up the only reason it isn't for ours because. 1 the hood has to be modified or a hood for 2002-04 used and 2 the headlamps the would need to be modified for the gap or new ones placed but all in all it bolts the same
Thats great to hear :D. Do you know what modifications the hood would need? And as for headlights, I need to replace mine anyway because of broken brackets for auto level system. would 2002 headlights do the trick then?
