2000 A6 2.7L transmission a5s 325z Filler Plug?
I decided to change the tranny fluid and Ince I got under the car , i found that I have 5HP19 (A5S 325Z) transmission, I found a Picture as to where the drain and filler plug is, but when I look under the car , I cant find the filler plug anywere, any suggestions where it could be
RE: 2000 A6 2.7L transmission a5s 325z Filler Plug?
Found this info, But I still Cant locate the fill plug
http://www.zf-group.com/pdf/5HP19.pdf
It is actually recessed in from the bottom surface of the pan. Location of the hole is toward the rear or the car. PM me with you email and I will send you a PDF. It contains fluid change DIY with the fill plug location.
For some reason, they don't allow PDF to be loaded. Anyways, I convered PDF pages into low quality JPEGS. Here I try one at a time.
[IMG]local://upfiles/46004/B0D60E3BC69A43A28EB2528194F74C29.jpg[/IMG]
