2000 A6 2.7T help!!!
Old Jun 2, 2011 | 06:45 AM
magiben2k5's Avatar
Yea that's d one I replace. I went by this instructions when I changed it.
http://m.audiworld.com/showthread.php?t=2804520
is there another that makes d needle move or a fuse or something?
Old Jun 2, 2011 | 08:29 PM
FonzoB5S4's Avatar
this could be due to a bad thermostat. vag-com your car and see what codes come up, but i'm pretty sure you have a bad thermostat. your needle needs to be dead in the middle unless you have a performance oil cooler.
Old Jun 2, 2011 | 09:49 PM
magiben2k5's Avatar
Thanks 4 replying!
Yea Im gonna have to vag-com d car and see what's going on cause I can't find anything unplug around d area where d sensor is. I just didn't want to take d car to d shop again but I guess I have no choice now.
Old Jun 3, 2011 | 02:18 AM
FonzoB5S4's Avatar
take it to autozone or somewhere similar and they can scan your car for codes for free. for the t-stat i think you'll need to remove the timing belt to get to it or at least the passenger side of the timing belt.
Old Jun 3, 2011 | 09:37 AM
magiben2k5's Avatar
Thanks, I didn't know autozone could check it free!!
Damn... Removing timing belt? sounds like 2 much 4 me to even try! Lol if that's what it is them I'll just do a complete timing belt, tensioners, water pump, etc. I was thinking of doing it around 170k miles anyway. I just can't do it now$$ :-(
Old Jun 3, 2011 | 03:24 PM
FonzoB5S4's Avatar
yeah it is a bitch and i did mine when i did my t-belt job. go to ecs or blauparts to get the t-belt kit. vast might have a good one as well, unless there special is over. get the best one possible. if youre having someone else do it(a shop) dont get the one with the cam-locking tool, so you can save some cash. you wanna replace as much as possible while doing the t-belt. i suggest getting a new/rebuilt starter and alternator while in there and a new fan clutch. i'm in the midst of an engine pull right now so i'm just naming off some of the things i'm doing while its out and i have room to work on it.
i know this **** gets CRAZY expensive so i'd learn to wrench as soon as possible!
Old Jun 4, 2011 | 10:50 AM
magiben2k5's Avatar
Took it to autozone n got this codes: P1690, P1296 guy told it has to do with d coolant sensornot being plug right n open circuit, I don't know what d hack? I'm gonna dobble check everything once again maybe I messed up d wires while pulling d clip fron d old sensor? He said that if needle is not moving at all that where d problem is. mine does not move one bit! So here we go again n I can't figure it out I guess I'll just wait 2 months n do d timing belt etc, n let them figure it out :-(
Old Jun 4, 2011 | 10:58 AM
  #18
magiben2k5's Avatar
Thanks 4 replying!
Yea I'm gonna check those sites u mentioned for d timing belt kit!
I'm trying to learn how to work on these cars myself but sometimes is just to complicated! Lol I mean I worked on my motorcycles n some old Japanese cars b4 but never on an Audi n also nothin to crazy either, my girls father helps me once I a while but is still hard to work them. I tell u what tho even tho my car is 11 years long it still drives like a champ!!
Old Jun 4, 2011 | 11:21 AM
  #19
bigdadi's Avatar
Strange ... make sure both ends of coolant temp sensor sit properly and the old black O-ring is out, the plastic clip is clicked in.
Old Jun 4, 2011 | 01:17 PM
  #20
magiben2k5's Avatar
Thanks, I'm gonna check everything right now n see what happens!
