2000 a6 2.7t.. replace now or wait..
Old Feb 10, 2009 | 05:08 AM
5ln's Avatar
5ln
Default 2000 a6 2.7t.. replace now or wait..
ive got a 6 speed with 90k on it. i know i need to go ahead and replace my valve cover gaskets (smell the oil burning).. someone told me i should replace the timing chain.. water pump.. etc. is this preventive maintenance or can i wait until it fails completely? also.. i hear alot of grumbling.. knocking sounds on my front end whenever i hit small bumps. i know its hard to diagnose w/o being next to a car..
any ideas?
Old Feb 10, 2009 | 07:34 AM
bob martin's Avatar
Time to spend some money! You DO NOT want to wait until the timing belt fails as that will bend your valves. In addition to the valve cover gaskets, you will need the cam chain tensioner gaskets and the spyder pipe to resolve the burning oil smell issue. You are also going to need new control arms and tie rod ends. Do you do your own work? If not, ouch!
Bob
Old Feb 10, 2009 | 06:03 PM
ppgoal's Avatar
It's not that bad -- a full TB job with all the parts should set you back about $1000 at a good indie and $1500 at the dealer. Not sure about the other gaskets, it depends on whether they are leaking or you believe in that level of preventive maintenance. I never had the gaskets changed and I have no leaks at 128k miles. Suspension is original and tight.
strker16
Mar 11, 2012 12:01 AM
akshaykedia
Apr 28, 2010 09:59 PM
archstanton
Oct 29, 2007 07:11 PM
KÖNIG A6
Aug 21, 2005 02:51 PM
andrew.vint
Jun 15, 2005 06:56 AM
