2000 A6 4.2 ABS Control Module
Old Jun 21, 2010 | 01:45 PM
stpaulman's Avatar
Default 2000 A6 4.2 ABS Control Module
Hi, after getting the ABS + flashing "brake" light and searching the posts, it looked like my issue is the ABS Control Module. Lots of recommendations for ModuleMaster - checked them out, read the directions, watched the video. Felt good about doing it.
So here's the problem - according to the directions/video, I should be able to loosen and drop the windshield washer tank. I can loosen it just fine, but there's no way to drop it - right underneath the tank there are three blue spheres (what the heck are they?) blocking the way. No way to get the tank out. I'm guessing this is something unique to the 4.2?
Has anyone run into this? Or I may be able to get the module off with the tank in place (it's going to be close!). With the wheelwell liner out, I can get to the screws underneath the unit so I should be able to loosen the unit, just don't know if I can cut the corner.
This would be so easy if I could get the darn tank out.......
Any advice?
Thanks!
Old Jun 23, 2010 | 04:08 PM
My Ryde's Avatar
I had the same problem and had my mechanic do the job for me. I was tired of paying crazy labor so I invested in the Repair Manual the dealer uses. I can look into how to remove the ABS Module. Send me your email address and I will try to send it to you.
Old Oct 27, 2010 | 07:06 PM
tdog05's Avatar
Default ABS Repair
Can you send me that manual?
thanks!
Troy
tdog05@gmail.com
Old Oct 28, 2010 | 08:20 AM
bob martin's Avatar
The blue spheres are vacuum reservoirs. They can be removed.
Bob
Black02
Nov 17, 2014 05:50 AM
EssexGuy
Oct 3, 2010 03:42 PM
das-ist-mein-Audi!
Apr 23, 2010 02:00 PM
Boober
May 26, 2007 05:30 PM
JDriver2
Jul 10, 2006 11:16 PM
