2000 A6 Avant rear rotors and pads
You need a tool to turn and press the piston at the same time. Other than that, make sure to get the correct rotors. There are 3 different types on A6. I believe all US spec avants came with 255 mm diameter rotors; however, there are 2 different varieties of 255 mm rotors. One has 43.85mm hat height, and the other has 37.85mm hat height. One way to figure out is to call a dealer with your VIN, and the other is to take the wheel off and measure.
AWD_Addict
11-22-2012 12:25 PM
pilot5.0
05-19-2008 09:50 PM
