2000 Audi A6 won't reverse
Posting in the A6 section as well (general tech previously).
New to the forum and just purchased a 2000 A6 4.2L auto with almost 70k miles from an auction. I put the car in Reverse and I did not feel any engagement of the tranny at all and gave gas and the car acts like it in in neutral. I've read thru some of the previous posts and from what I've learned so far is that it could be the Valve body or Reverse Drum or just require a whole tranny rebuild. So my question is, how would you determine if its the valve body and not the whole tranny? Also what are the signs of a reverse drum? Unfortunately at this point, I cannot drive it because the I don't have the new title yet and DMV will want to inspect it as it carries a Salvage title from being vandalized. Thanks in advance for any assistance. |
Vandalized. Hmm... Maybe they stole reverse;)
But more seriously, get a VAG-COM and do a scan. There is a good chance it will tell you the problem.
Thanks for the response.
Do I need to take it to a mechanic for that? The problem is that I can't drive it until the issue is fixed and it passes DMV in order to get registered :( I am guessing its some sort of diagnostic tool. If someone out there has one, can I borrow it or rent it? I am located in Palo Alto CA. |
VAG-COM is a diagnostic tool made by Ross-Tech in the US. It consists of an OBDII cable and software. If you plan to own an older Audi it will pay for itself (~$350) many times over.
The vag-com from Ross-tech is on my list, but I've been using the cheapy ebay ones for my 2001 A6 Avant and it is getting the codes I need just fine.
Thanks for the info. I have inquired about one from some friends and should be able to borrow one. Will give it a try. I don't plan on keeping this car so don't really want to invest in one. I will post the results of the tests in case it helps anyone else.
Sharing Fault Codes
So I ran the VAG-COM diagnostics and the transmission portion of the check did not return any fault codes so not sure what else may be going on here :confused:
Here are the results. Sorry for the long thread: VCDS Version: Release 12.12.0 (x64) Data version: 20130910 Saturday,05,October,2013,11:01:09:40880 Chassis Type: 4B - Audi A6 C5 (1998 > 2006) Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67 75 76 77 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No: 4D0 907 558 S Component: 4.2L V8/5V 01 0008 Coding: 06652 Shop #: WSC 42286 VCID: 3D71ED2D37EE1EF6BF5-5124 3 Faults Found: 17521 - Oxygen (Lambda) Sensor; B1 S1 P1113 - 35-10 - Internal Resistance too High - Intermittent 17539 - Oxygen (Lambda) Sensor; B2 S1 P1131 - 35-10 - Internal Resistance too High - Intermittent 17549 - Load Calculation Cross Check P1141 - 35-00 - Implausible Value Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01L-927-156.lbl Part No: 4B0 927 156 BS Component: AG5 01L 4.2l5V USA 1414 Coding: 00002 Shop #: WSC 02325 VCID: 79F9393D6346E2D6D3D-5142 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl Part No: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D10 Shop #: BB 24334 VCID: 1C3700A98C3477FE68B-5142 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl Part No: 4B0 820 043 K Component: A6-Klimavollautomat D64 Coding: 00180 Shop #: WSC 02325 VCID: 224B3E51AE50410EA27-258E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4B0-959-655-AI8.lbl Part No: 4B0 959 655 F Component: Airbag Front+Kopf 0002 Coding: 00404 Shop #: WSC 02324 VCID: 3365CB1501AAD886591-5142 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4B0-907-487.lbl Part No: 4B0 907 487 Component: E Lenkrad Elektronik D03 VCID: E9D9E97D93E6D256A3D-4B82 1 Fault Found: 01426 - Controls in Steering Wheel (E221) 49-00 - No Communications ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4B0-920-xxx-17.lbl Part No: 4B0 920 980 M Component: C5-KOMBIINSTR. VDO D09 Coding: 03283 Shop #: WSC 00000 VCID: 2F6DC765ED82FC663D9-5124 No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 4B0-962-258.lbl Part No: 4B0 962 258 J Component: Central Lock/Alarm D33 Coding: 15885 Shop #: WSC 02325 VCID: 306FC419F0BCE39E243-4EB4 11 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch; Passenger Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 00955 - Key 1 09-10 - Adaptation Limit Surpassed - Intermittent 00956 - Key 2 09-10 - Adaptation Limit Surpassed - Intermittent 01574 - Alarm triggered by Door Contact Switch; Rear Right 35-00 - - 01573 - Alarm triggered by Door Contact Switch; Rear Left 35-00 - - ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No: 4B0 959 760 A Component: Sitzmemory D05 VCID: 2B55D375D99A8046111-4AEC No fault code found. ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-178.lbl Part No: 4B0 951 178 A Component: Innenraumueberw. D04 Coding: 00101 Shop #: WSC 02325 VCID: 26432241C278BD2ECEF-522E 2 Faults Found: 01349 - Alarm via Theft Warning System; Front 35-00 - - 01350 - Alarm via Theft Warning System; Rear 35-00 - - ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4B0-907-357-DYN.lbl Part No: 4B0 907 357 B Component: dynamische LWR D03 Coding: 00020 Shop #: WSC 02325 VCID: 275D2F45C572A426F59-4B06 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8D0-035-1xx-56.lbl Part No: 4B0 035 195 A Component: Radio D00 Coding: 00017 Shop #: WSC 42010 VCID: 1E330AA19A2865EE86F-4B38 2 Faults Found: 00855 - Connection to CD changer 49-00 - No Communications 65535 - Internal Control Module Memory Error 00-00 - - End --------------------------------------------------------------------- |
