2002-2006 A4 or S4 have same bolt pattern as 2001 a6 4.2?
RE: 2002-2006 A4 or S4 have same bolt pattern as 2001 a6 4.2?
Yup, 5x112 bolt pattern, they are the same. That is a sharp set of wheels/tires there.
THIS IS A DUPLICATE POST. ANYTHING 5X112WILL FIT ON YOUR A6 BOTTOM LINE. THERE MAY BE AN INSTANCE WHERE YOU MAY NEED WHEEL SPACERS.
Agree.....but you need to be wary of the offset. 5x112 is the standard size, but the offset plays into the picture with steering and clearing your calipers. 18" is the recommended size and 35mm offset should clear your calipers and not rub anywhere. 38mm has been known to work as well but with bigger calipers you might have an issue.
