2002 Audi A6
Old Dec 19, 2011 | 07:02 PM
ldale's Avatar
Default 2002 Audi A6
I have 2 issues. The first is that I have owned my A6 for almost 6 wks. And in that time I've had the oil light come on twice and have had to oil. I have seen no leaks and no dark colored exhaust. What's the deal?
2nd problem I have a whinning noise coming from the engine compartment when I start it up and it only lasts for a few minutes. Is it something I need to worry about.
Old Dec 19, 2011 | 07:39 PM
02A6Beau's Avatar
#2= secondary air injection pump
#1- well could be a whole bunch of things. the oil has to be going somewhere. if you still have the belly pan on, it may be that when the oil leaks out it lands on the belly pan, not on the ground so you aren't noticing it. do you have a burning oil smell/light smoke under the hood when the engine is warmed up? Valve cover gaskets are a usual suspect in this case. see if you can narrow it down a bit for us and we can make better guesses.
also it helps to know what engine we are discussing
finally, Wilkommen to the forums. enjoy your stay
sports265
Jun 10, 2009 10:37 PM
rkmA4
May 25, 2009 07:29 PM
nukauto
Feb 2, 2008 11:02 PM
bullitz400
Feb 2, 2007 09:58 PM
