2002 Audi A6 2.7t Turn Signal Relay Squealing Loudly
So today I tried replacing my bad turn signal relay that wouldn't function if i did "Left or Right" but worked when Emergency flashers were going.
When I installed the new one, I thought it was easy and I was done. No sir. :( When I turned on the car to test it I got a really annoying squeal coming from the relay itself. I originally thought I had another defective part but when I plugged the old one back in it was still there. I haven't been able to find any information on said problem. Has anyone ran into this or anything similar??? Thanks Guys. I also made a video demonstrating what Im talking about. |
Hi
Its actually not the relay it self that makes this happen. Itīs the combi arm (turn signal arm) that is the source of this noise. I had something similar to this in my car and I too tried to change the hazard swith/relay to begin with. Then I got a new turnsignal combi switch and that fixed it. I hope this helps |
I have the same problem did the same thing dont know what to do
did you change your turnsignal combi switch?
