2004 A6 2.7 Timing Belt Info.
The dealer tells me that I should replace the timing belt at 95,000 miles. Is the correct ? Also are there any web sites with good instructions and pictures on procedure to replace belt. I found some for the v8 but not the 2.7 v6.
Thanks |
Sooner, I'd recommend doing it at 70-75k... You do not want to to be cheap on that and postpone... it could result in some serious and costly damage
2002-2003 Maintenance schedules require TB replacement at 105k.
2004 - replacement is to be done at 75k. Maintenance schedules are posted on Audi’s web sites. |
Thanks for the info
