2006 A6 Fog Lamp replacement
Old Jul 7, 2011 | 08:59 AM
hdspringer98's Avatar
Default 2006 A6 Fog Lamp replacement
I'm trying to replace the fog lamp assembly (cracked lense). I can't seem to be able to remove that grill cover (drivers side US). I popped the clip on the left side of the grill cover but the grill just won't come out. What am I missing....this should be easy.
Old Jul 7, 2011 | 11:34 AM
Default Still stuck
I've been at it for 30 minutes trying to get those ******* fog light covers off on the driver side. I've got it out near the center of the car but the rest of the cover simply does not budge. PLEASE I'm begging here for help. Why is this so ******* hard?
Old Jul 7, 2011 | 03:39 PM
Default Solved
Ok, all the posts and mentions found via Google were not very clear. I did manage to solve it. Here's the real deal: With a screwdriver pop the left side tab and gently pull out the left side of the grill cover. (this is for driver side grill cover). Then there are 2 tabs hidden on the far right of the grill and in some cases if you pull the grill towards the middle they come out....they didn't in mine. So I gently inserted a flathead screwdriver between the bumber and grill cover and gently worked it. Eventually it popped out and revealed the easy to replace fog lamp assembly.
Old Nov 25, 2014 | 01:42 PM
dluvsd2's Avatar
That was simple enough. thanks.
guzutite
Nov 4, 2014 12:33 PM
desertsnake1991
Dec 11, 2012 07:04 PM
TJT
Sep 7, 2010 11:16 AM
dtkelley2005
Oct 23, 2007 02:39 AM
TeeterTawter
May 24, 2007 10:37 AM
