MJenkins |
05-17-2018 10:17 PM |
2007 A6 Won't start
Hey guys this is my very first post here, and it seems I am in quite the pickle. I recently purchased a second hand 2007 A6 Quattro. I've had it for almost two months, and on Monday when I went to leave for work I turned the key and got nothing. The radio comes on, but there is no engine activity at all. No starter click or any other obvious issue. I took the battery in to have it checked out hoping for an easy fix, but the battery is perfect. I've done a lot of digging, and this seems to be a fairly common issue with this model, or at least seems common based on the amount of responses I found online. It appears that this problem is the same as mine. I poked around a good bit after identifying that to see if I could find a solution I could implement myself instead of spending half of what I just spent on the car two months ago at the dealer. I found
and other similar videos. I thought it was worth trying, but I was hoping to avoid buying a $300 cable if possible. So I ordered
on Amazon in hopes that it would work to clear the code. As you can see by my hopeful attempts to fix it I am trying to do so on a fairly tight budget. Has anyone experienced a similar issue, and how did you end up getting it corrected? I simply cannot afford to have the dealer bill me $2,000+ to get this fixed. Any help at all is greatly appreciated. Thank you.
