Sponsored by:
Sponsored by:
Need help asap
Old 12-27-2012, 10:10 PM
Paul1234's Avatar
Default Need help asap
Had a bad rain storm today and I noticed water is dripping in my car through the dome light panel. There is no cracks in my windshield or my sunroof. Can someone please tell me what's going on??
01 Audi A6 2.7
Thanks.
Old 12-28-2012, 07:54 AM
CRF Rider 57's Avatar
Have not had that issue but I am aware of clogged sun roof drains causing water to migrate in to the interior and cause damage to the TCM. Worth a check.
Old 12-28-2012, 12:11 PM
Paul1234's Avatar
How can u tell if there clogged? I see the drain holes but there is nothing I can see.
Old 12-30-2012, 01:25 AM
TwinTurboC5's Avatar
Find yourself some stiff wire or cable and feed it up the sunroof drains that exit at each of the front door jambs. The water seeping in from the location you describe is most likely being caused by a sunroof drain that is blocked.
Old 12-30-2012, 04:04 AM
Euge82's Avatar
Most likely the sunroof drains. But first open and close the sunroof, sometimes it needs to re-set if it is not used very much.
With the sunroof open look for pooled water. There are two drains towards the front. Open both doors. Pour some water in tray area of the sunroof and see if it drains out of the door drains. If they are clogged feed some wire down each tub. You may have to do it a few times.
It could be the seal right at the top of the window.
Old 01-07-2013, 03:12 PM
daftmutt99's Avatar
Coming in from the pollen filter had to cover mine up stopped straight away
Old 01-08-2013, 11:20 PM
Paul1234's Avatar
Thanks everyone. I finally got it. Some how there was a hole in one of my drains so I had to have it replaced. Thank god my gfs brother works at an auto shop.
Mmspartan
06-14-2011 05:14 PM
zerodegre
09-20-2009 11:33 PM
dejahn23
09-22-2008 07:28 PM
bhunt17
02-21-2008 07:07 AM
silveraudib6
02-08-2008 04:11 PM
Quick Reply: Need help asap
