97 Quattro front end crunching upon hard turns???
Sitting at a small intersection, steering wheel cocked full for a left turn, I had to gun it to get out into the traffic. What I heard scared me! Sounded like rusted stiff ball joints! I say ball joints with an s, because there seemed to be more than one player for the stressed crunching sounds? So here I have an all-wheel drive car, with also a chatter when making any hard turns to boot...(thought is wasa normalQuattro thing, as was told here) but now I'm wondering. My friends 1999 Outback never uttered a whisper when hard turning, so I am wondering what may be the problem........anyone with a clue?
RE: 97 Quattro front end crunching upon hard turns???
Take a look at the CV boots to see if they are torn.
Rack up the vehicle and look at your upper control arm bushing with a light, they could be torn causing the link to flop around like a fish.
Quattro AWD systems are far different than any subaru, its basically a tractor differential called the torsen diff which is fully mechanical. When turning very hard you can get a slight chatter, but its hardly noticeable.
ORIGINAL: auditech79
http://www.ecstuning.com/stage/edpd/...viewimage.html
This is what you need if you wanna eliminate any suspension noise and take care of everything at the same time.
The kit is only $499, which is better than OEM.
Im the same way, gotta have my cars in tip top shape.
The upper control arms usually only last about 60-80k depending on the driver. The lower arms usually never have any problems but the tie rod ends do!
For the price of the ecs tuning kit its a steal, the dealer would easilly charge $1,500 just for the parts alone that aren't even as good as the Meyle kit.
