a6 2.7t issues
Old Nov 2, 2008 | 02:44 PM
Darivative's Avatar
Default a6 2.7t issues
I just bought a 00 2.7t a6 and have a few questions.
Cluster is scrambled is this an expensive fix?
Trans. is making a whining noise and there is a cel code for service transmission.
Lower ball joint is knocking and i just bought a new one is this a easy fix?
thanks
Old Nov 2, 2008 | 07:13 PM
james0013's Avatar
For the cluster these people will re condition the cluster for about $350 but you have to remove it:
page to order:
http://bba-reman.com/content.aspx?co...ashboardfaults
Link to removal Instructions
http://www.audiworld.com/tech/elec106.shtml
Old Nov 2, 2008 | 09:25 PM
Darivative's Avatar
Thanks for the reply
I will be defiitely be sending it to them.
Any answers on the trannny issue?
Old Nov 3, 2008 | 07:53 AM
bob martin's Avatar
Trannies are expensive to fix. Have it checked right away. Torque Converter seems to be the common failure.
Ball joints can be easy (lower rear) or hard (any of the other three). You should plan on replacing the whole set while you are at it. Also, check your CV joint boots. If they show any signs of cracking, do them whille you are in there. Otherwise, you will have to go in there again soon.
And, while you have it this far apart, put in new wheel bearings.
Bob
Old Nov 3, 2008 | 04:24 PM
Darivative's Avatar
I got it looked at today.
Whinning is the power steering pump
cv joint and upper link needs to be replaced.
I will getting all this done thursday.
Other than the cluster being scrambled everything is good.
Almost time to start modding
tofast2belast
Sep 19, 2012 06:08 PM
ImTheDevil
Aug 3, 2011 09:11 PM
awk81
Jan 10, 2007 02:56 PM
rfors777
Jun 17, 2006 12:26 AM
kenestle
Dec 4, 2004 08:31 PM
