Lower Driver Door Seal part number
I noticed that my lower driver's door seal on my 2008 A6 is deteriorating. I have looked at the online parts catalog and in a copy or EKTA that I have but I cannot identify the part with certainty. Here is a photo
Does anyone know the part number for this seal?
I tried to find that too, can't easily do it. I would need your vin number just so Audi will talk to me about finding it. I looked for that same seal for 2008 A8's and A4's and found nothing. It might be part of that lower molding that appears to be separate from the door, but in looking at pictures of cars on ebay I don't see a body line. Door looks one piece from top to bottom.
Jeff - thanks for looking.
The door does have a lower molding about 60 mm wide that runs along the bottom of each door. The rubber I am looking for is sandwiched between this piece and the metal of the door. Apparently it comes as part of a kit with the molding.
Figured it out, that rubber seal is part of the molding. Shown on ebay here but it's the wrong part number. Picture is a little dark but seal can be seen on one of the pictures. We would need your vin to figure out which of the two choices you would need. They run 132.58 or 145.45 for it depending on the options you have for the door sill that this seal must mate up against. Plus it would need to be painted. We have one of them in stock so we went to check and that rubber seal is part of the molding. This one we have is already painted black. Must have been sold to a body shop and they painted it, then realized they needed a right and not a left. What I don't know is if it can be transferred over, as in buying the molding just for the seal to avoid the painting charges. I didn't look at the seal myself, a coworker did this for me. I used your picture to show him what to look for.
kurtkarl
10-02-2008 10:59 AM
