Sponsored by:
Sponsored by:
A6 accelerator sticking – multitronic gearbox
Old 08-08-2008, 09:39 AM
Dew Vou's Avatar
Default A6 accelerator sticking – multitronic gearbox
Hello all
The issue I have is that on occasions, I brake to stop but the car seems like it doesn’t want to stop – dangerous.
First, I thought the brake wasn’t working
After a few more experiences, I thought that the multitronic was occasionally delaying shifting gear and applying more positive drive than I’m used to
Upon further occasions and closer monitoring, I now think that the accelerator is sticking which makes sense as it feels like I’m fighting a level of torque when braking (also feels like the brake pedal is stiff or stuck).
Did some tests in neutral
Press the accelerator lightly so that it reaches 1250rpm, release accelerator and observe revs
1. Most of the time, the rev counter goes back down to 750rpm
2. On occasions, it stays at 1250rpm (like it was in cruise control or something) until the brake pedal is pressed (first touch of brake does nothing, must apply strong force to overcome accelerator and then it sounds like its about to stall but resides back to 750rpm
3. On occasions, even though I press the accelerator the same amount – revs go up to 2500rpm, a little inconsistent and gives the car a bit of a jolt sometimes
Anyone know a likely cause of this – throttle body sticking, accelerator cable, electronics, or hopefully not the multitronic gear box?
Regards
Old 08-08-2008, 10:25 AM
hxgaser's Avatar
What year is your car? Engine type?
Old 08-08-2008, 03:31 PM
kimi's Avatar
check all vacuum lines and make sure they are all connected.
Old 08-10-2008, 01:35 PM
Dew Vou's Avatar
Its a 2003 1.9 TDI
Just noticed that the cruise control switch was in the on position. Havn't had the issue since but its only been one day.
I'll ask my mechanic to check the vacuum lines - I wouldn't know where to look
Thanks
Old 08-10-2008, 11:04 PM
hxgaser's Avatar
On my 2001 US spec A6, there is a vacuum diagram printed on the underside of the hood/bonnet. There should be one on yours to I would imagine...
If the problm comes back, then check the throttle body for any objects or residue. Then check for any vacuum leak.
Old 08-26-2008, 12:01 PM
Dew Vou's Avatar
Hi again
Issue reapperaed so I had the mechanic take a look at it while he was installing a towbar. He took it for a test drive and of course there was no sign of the problem. He checked the vacuum lines and throttle body and said everything was OK suggesting that the issue was electronic and not mechanical. It happens at least once a week.
He did note a delay in the accelerator kicking in when taking off from a standstill (ie you press the accelerator, 2 seconds later - acceleration begins) - I noticed this too but read somewhere that this is normal for the multitronic transmission - anyone know, is it normal?
Guess I should probably try and get a vagcom reading somewhere - there are no issues on the dashboard screen though.
Regards
Dew Vou
Old 08-26-2008, 01:20 PM
Dew Vou's Avatar
Just to add to this, on the way home in traffic - I was at a standstill, the engine idleing at 800rpm in drive mode, my foot on the brake pedal - engine then decides to increase revs to 1200rpm with no input from me - weird. Also, to move forward at 5mph on flat ground, the engine had to go up to 2000rpm. When applying the brake to stop again, it feels like the gearbox goes up a gear. Would it be possible that the gear box is confused about what gear its in, that maybe it thought it was moving down to second where it actually moved up to second?
Regards
Dew Vou
Town573
B7 Models
14
03-08-2015 06:14 PM
cheebiechi
03-03-2014 03:46 PM
arsenal-das-it
B7 Models
02-06-2011 08:15 PM
audilthr
08-03-2009 06:12 AM
chelsea4me
05-07-2006 05:36 PM
Quick Reply: A6 accelerator sticking – multitronic gearbox
