A6 Central locking problem - DTC 01560
Hello.
The car: Audi A6 [C5 2002] 2.5TDI [AYM] EU version.
The problem: I cannot unlock and open passenger door in any way -
there is no possibility to unlock it using the key, the RC and even
from the inside.
I've got huge problem with central locking system in my A6 - the front passenger door are jammed closed and it's impossible to open them. The central locking opens all other doors successfully [via key or RC] and tries to unlock the passenger door also but with no success. If I try to open the door from the inside the lock button lifts up while the handle is pulled but goes down again when the handle is released [without opening the door] Trying to open the door with the outside handle [while the inside handle is pulled open] also doesn't work.
I can't take the inside panel door off since the door is closed.
Enviroment: the car stood 20 days in my garage [I've got knee injury so couldn't even walk].
After I had plugged pc to the car's obd VAG-Com said this:
After I had carefully read the following knowledge base:
http://wiki.ross-tech.com/index.php/01560 ,
I logged the measuring blocks.
Here is the effect:
It's obvious that passenger door can't achieve "Not safe" state and
in effect it's impossible to go from "Locked" to Unlocked" state.
What to do since it's impossible to open the passenger door?
Would You be so kind and tell me if there are 4 independent "Central
Locking Actuator" devices or one device?
If anyone has heard of anything similar or has any suggestions of how to get round this I would greatly appreciate it.
from the inside.
VAG-COM Version: Release 311.2-N
Control Module Part Number: 4B0 962 258 D
Component and/or Version: Zentralverriegelung D34
Software Coding: 06721
Work Shop Code: WSC 02325
2 Faults Found:
01560 - Passenger Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
2 Faults Found:
Here is the effect:
.It's obvious that passenger door can't achieve "Not safe" state and
