a6 starting problems
Old Jul 12, 2006 | 06:01 PM
a6 convert's Avatar
Default a6 starting problems
HI. I have just purchased my first a6 which is a 95 2.0e. sometimes the car wont start and a spanner type symbol flashes on the dash. i have noticed a relay clicking noise when i try to start the car. if it clicks aound 10-12 times the car wont start but if it clicks 6 times it goes. sometimes it takes up to 10 minutes and about 60 turns of the key. has anyone any advice?
Old Jul 12, 2006 | 07:18 PM
techbod's Avatar
Default RE: a6 starting problems
could be the fuel pump relay, coolant temp sensor but you must have codes stored with this problem, the spanner light will be the EVAP system because it is starting so the excess fuel is being pumped into the carbon canister which would set an emissions warning, try fitting new spark plugs first
Smokin Tubes
Feb 5, 2012 10:11 AM
joe4123
Sep 16, 2009 11:17 PM
joe4123
Jun 19, 2009 08:05 PM
james0013
Sep 2, 2008 11:22 AM
Limmy711
Sep 15, 2005 02:11 AM
