a6 won't move !
help.... my friend has an 96 a6 that suddenly won't drive at all. car starts and runs fine. trans gear selector works. can be put in r or d ect. but car just won't move. dove it to the store and when she came out this happened. at first she thought it was a transmission failure but is skeptical as the trans functioned fine before this. never slipping, shuttering ect. just happened in the 5 min. she shut off and then came out. any suggestions?
thanks! |
RE: a6 won't move !
Wish i could help:(
RE: a6 won't move !
Are the tirestouching the ground? One of my favorite pranks is jacking up a buddies car and slipping some blocks under his rear axle.
RE: a6 won't move !
hmm.. never thought to check ..[sm=smiley36.gif]
RE: a6 won't move !
Parking brake?
RE: a6 won't move !
Check this post... https://www.audiforums.com/fb.asp?m=751428 Might be related
RE: a6 won't move !
dodgey gear linkage?
probably some silly bit of plactic has worn/cracked like their ignition switches do |
RE: a6 won't move !
Its either the transmission range switch (TR) which would have a fault codes stored in the transmission electronics. Or you blew one of your axles. You lose one axle, the others won't work.
RE: a6 won't move !
ORIGINAL: Burzum Are the tirestouching the ground? One of my favorite pranks is jacking up a buddies car and slipping some blocks under his rear axle. |
RE: a6 won't move !
ORIGINAL: Burzum Are the tirestouching the ground? One of my favorite pranks is jacking up a buddies car and slipping some blocks under his rear axle. Lol, i gotta do this one day |
