ABS & Brake light - Have a Code
Old Feb 5, 2008 | 04:07 PM
ThePizza's Avatar
Default ABS & Brake light - Have a Code
Okay, so my car started displaying the ABS and Brake light and beeping three times. I just got the VAG-COM cable I ordered off of Ebay and plugged it in. The ABS controller doesn't seem to respond, but the engine controller is giving the following code:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
I figured I had a failing ABS unit, but now I am even more confused. Can anyone tell me what might cause this P1606 code?
Old Feb 5, 2008 | 11:22 PM
dankhound's Avatar
Default RE: ABS & Brake light - Have a Code
Still sounds like a bad abs control module. The ecm just isnt seeing a signal it expects to see from theabs since the abs control module is dead so it throws a fault for a bad signal.
Old Feb 5, 2008 | 11:39 PM
auditech79's Avatar
Yes that fault code is usually thrown when a faulty ABS module is present.
The only other cause would be a faulty IAT sensor, which really isn't plausible.
Old Feb 7, 2008 | 12:29 AM
ThePizza's Avatar
Alright, thanks guys. I am going to ship this off to modulemasters.com and see what turns out. I'll let you all know!
Old Apr 23, 2008 | 04:58 PM
dcdesign2000's Avatar
Any luck with the ABS Module?
My friend's 4.2 is beeping with ABS & Break lights after he drives on the road for 15 minutes. Then it beeps again and goes away in 15 minutes.
I wonder if he has the same problem.
Any suggestion?
Thanks!
TexasLexus71
Apr 12, 2012 05:38 PM
blanthony
Mar 25, 2006 01:18 PM
LilBlackS4
Feb 17, 2006 08:55 PM
