AC?
AC?
ok so i was trying to use my AC and i put the temps all the way down to low and all i get is warmish air....is there an AC button im missin ? should it come on automatically. or do i need a recharge?
one more thing.. my rear door speakers wont work..the tweeters and the lower ones....whats wrong with them? its only on the back two doors...
RE: AC?
Is your recirculation button or Econ button on? If so turn both off, if this still does not fix your problem then yes recharge. also there is no "AC" button.
I'm assuming you have the stock non bose system. The rear speakers are powered by the amp in your trunk inside the sub on the rear right side. Does the subwoofer in the trunk work? If neither the sub or rear speakers work than the amp may be at fault.
