Advice on Cat Converter and 02 Sensor Codes
Old May 26, 2010 | 10:33 AM
Lance Kragenbrink's Avatar
Originally Posted by ninetynineA6Q
My wife's A6 has the 2.8, so I don't know how different the exhaust system is from a 2.7T, but on hers, using universal cats was by far the least expensive fix, and it wasn't all that difficult. I disconnected the coupling behind the cat on each side, and once you cut the cats off, you can pull what's left of the down pipe down at the flex coupling enough to weld the new cat on without even taking the pipe loose from the manifold. The universal cats I got are round, so you lose about an inch of ground clearance, but for $60 each, its a worthwhile tradeoff.
nintynineA6Q
If you dont mind me asking, did your car have a CEL or codes telling you you had bad cats? And if so, did the universal cats make the CEL go away?
Also where did you get the universals?
Thanks
Old May 26, 2010 | 08:59 PM
ninetynineA6Q's Avatar
I think the model number for the ones I bought is 642-53004, and if I remember right, I got them from Jeg's.
The CEL was on before I replaced the cats, but I don't have a scanner, so I don't know if anything changed afterwards. One of these days I'll have to look into the whole VAG-COM thing since I think I'm going to have this car for a while.
Old May 26, 2010 | 09:21 PM
auditech79's Avatar
The 2.8L has a LOT more wiggle room around the downpipe area than the 2.7T, you won't be able to do that procedure without pulling the entire downpipe.
To the OP, if you are unsure of where the cats are, look for the O2 sensors. If there isn't an O2 sensor after what you think is the cat, then its not a cat.
Old May 27, 2010 | 09:07 AM
Attachment 7147
Thanks, did your Check engine light go out after installing the new cats?
Also, I heard that you can go to AutoZone for a free scan if that helps?
Old May 28, 2010 | 08:28 PM
The CEL is still on, so I need to figure out what it takes to reset it and then see which codes, if any, still show up. Somehow I doubt that the code scanner I have for my Mustang will work. I'll have to let you know what I find out. If only I could swap the Mustang's computer into my wife's car...
Old May 29, 2010 | 07:45 PM
NH_USA's Avatar
Do a search in this forum for VAGCom -- it will give you all you need to find a cheep code scanner and reset device for Audi.
Old May 30, 2010 | 04:42 PM
jhuffman's Avatar
I've read that the OEM cats on these cars flow really well and other than the downpipe one, provide little restriction. Anyone with aftermarket cats feel any difference after a change?
Old May 30, 2010 | 07:03 PM
  #18
auditech79's Avatar
N/A engines no, 2.7T engines, oh yeah. The set miltek sells adds 20ftlbs of torque just by adding their downpipes, even more if you go without cats. On turbo cars its all about flow.
Probably one of the biggest bang for the buck mods you can do besides a chip.
Old May 30, 2010 | 09:01 PM
  #19
I bet it would be hard to beat the flow of the empty factory cat I had, but really the only difference I could tell was that it was a lot quieter. Unfortunately though, getting rid of the loud rattle made it possible for me to hear that the center muffler is rusting through and leaking, so I have another upcoming exhaust project. I'm sure that crazy-shaped muffler isn't cheap, so I wonder if my wife would notice if I welded a couple Cherry Bombs together and replaced it with those. After all, there are two more mufflers back there. How much of a difference can it really make?
A4audiB5
Apr 8, 2013 04:39 PM
N1a6Germ
May 4, 2009 11:27 PM
tkrick
Feb 25, 2008 06:43 PM
that_boi_sk
Mar 7, 2007 02:55 PM
christianrbuss
Sep 1, 2006 01:25 AM
