Air Con problem - advice needed!!
Old Oct 3, 2006 | 05:24 PM
antoncole's Avatar
Default Air Con problem - advice needed!!
Hello you lovely people.....
I have a problem regarding the Air Con on my 1995 A6.
My AC has quit....
When i hit the button on the console for AC, the symbol lights up and the secondary cooling/condenser fan starts up ok.....
But, there is no drop in rpm or no compressor sound... which was all ok before, plus theres no cooling from the AC anymore.
I have identified the clutch power supply and when the button is pressed, there is no power supplied to the clutch...
I have even identified the relay.... it seems ok...
Is there some black magic computer wizardry involved anywhere that might be responsible or are there any obvious commom failure points i need to look for.
Any help would be appreciated.
Cheers.
Old Oct 6, 2006 | 02:13 PM
audiSean's Avatar
Default RE: Air Con problem - advice needed!!
You have climate control diagnostics built into your car, use them for answers or hints to your problem.
http://www.audiworld.com/tech/int5.shtml
Old Oct 6, 2006 | 02:31 PM
techbod's Avatar
check fuse # 11 ( 30Amp ) on the board at the end of the dash that's the one to the AC clutch
b007
Aug 4, 2011 09:42 AM
Lefty15
Feb 3, 2011 04:52 PM
idfnl
Feb 19, 2010 10:57 PM
masonV
Aug 5, 2009 06:14 PM
AudiA4Girly
Sep 13, 2007 10:29 PM
