AMI retro-fitted but issue. Any help please
Hi all,
just fitted the DAB and AMI units to my Allroad. It was running a later software (5150), so the units appeared straight away. The DAB came straight on and is just waiting for me to finish the aerial connections. The AMI module however comes up as selectable, but nothing I plug into it seems to work or charge. It just says "this item my not be connected properly or may not be working correctly. Is there a chance that something still needs to be turned on with VAGCOM. I did update to 5570 as well just to be sure, but discs one and two didn't need to update anything as the bits for the various updates on there all said no update required, latest installed. Only disc therefore was disc three which took it to 5570 which went fine but made no difference to AMI.
I tried wiring it without any splitters in place of the CD changer, and again, it comes up, but no go. Tried a phone and three types of iPods, but nothing.
Any advise gladly received.
Thanks all.
Allroad 3.0 TDI 2006 with MMI High
Thanks all.
Amy C
07-20-2008 11:27 PM
