Anyone here with a flashed or chipped 2.8l?
I was considering getting my ecu reprogrammed just to get a little more pep out of my 99 a6. But I'm skeptical about what kind of gains I would see, I can't imagine getting too much more out of a n/a engine. I was also worried about any downsides like fuel mileage or the driveline not holding up. I think I found a local spot that does it for $250 but I have to check my ecu# to see if its compatible.
So if anyone has experience I would appreciate the input. P.S. I have searched around and see everyone getting flamed and being told not to bother. Thats not why i am here, I just want to hear from someone who HAS done it, not someone who didnt bother. |
https://www.audiforums.com/forum/archive-engine-performance-parts-61/giac-ecu-tip-chip-97-2000-a4-a6-2-8-30-valve-78458/
https://www.audiforums.com/forum/computer-fuel-systems-27/2-8l-chip-27773/ https://www.audiforums.com/forum/audi-a4-8/giac-2-8-30v-chip-review-24796/ *https://www.audiforums.com/forum/audi-a4-8/speed-tuning-chip-%5B2-8-review%5D-83346/ Yes, some of them are for the A4 2.8 but there's NOT A TON of a difference. |
Thanks for the links, the Speed Tuning chip sounds great but Ill probably try out the GIAC reflash since there is an installer very close to me. Has anyone every heard of volo performance, I see there OBDII moduel on ebay but I am very suspicious.
Try GIAC. Speedtuning did not work out for me.
Originally Posted by hxgaser
(Post 1075630)
You can tell the difference after you are chipped, trust me. It's no 50+ HP HOWEVER, the more aggressive feel of the car should put a nice smile on your face.
I am wondering however if I MUST get the TCU chip along with the ecu flash. I see a few people including oc audica (sig)that mention the flash but not the tip chip but then Ive seen others say that the tip-chip is necessary or the trans will have problems after the ecu flash.
The result of any reflash - at least from a reputable company such as GIAC - should enhance, or sharpen throttle response. This is responsible for a good deal of the newly felt power, although it frees up power in the absolute sense as well, of course, by modifying timing and fuel curves.
As an aside, a flash such as this will actually increase gas mileage, in most cases. Win-win! |
Originally Posted by NuclearSymphony
(Post 1076873)
As an aside, a flash such as this will actually increase gas mileage, in most cases. Win-win! On a side note I just put a bottle of Redline fuel system cleaner in my tank and the car runs much much much better. The annoying hesitations I had from a dead stop, and between 40-50mph are practically gone. I just hope the effects are permenant. |
My Audi mechanic told me that flashing the chips would make a change, but over time I would loose it because the car is designed to adapt to the way I drive. So if I'm not continually stomping my foot into the gas, the car will "learn" that and change the way it shifts and the way the engine behaves.
Is this true? |
