Anyone replace a steering rack?
Old Aug 13, 2008 | 11:23 AM
madridlover's Avatar
Cool Anyone replace a steering rack?
Or know of symptons associated with a failing steering rack? Is the procedure to replace one hard? Should I have an Indie perform the operation?
Old Aug 13, 2008 | 11:56 AM
Ligist's Avatar
if ur power steering fluid is going down fast, like full 1 day almost gone the next, your rack is cracked/leaking yes it is hard to replace as its at the back of the engine (at least on older ones) and you need to remove a lot of stuff to get to it, and in parts alone the rack can be $1500+, however, there is a $12 solution that i did thats working pretty well so far lol, go to your local autoparts store (such as NAPA) and see if they have LUCAS steering sealer, it will condition/seal the rack and pinions in 1 or 2 bottles and all u do is add it straight in with ur fluid 1 bottle at a time (so u need to do it when ur steering fluid is low)
Old Aug 13, 2008 | 12:16 PM
No, I'm not losing fluid....at least not like that. I have seapage which I plan to replace one of my hoses but that's it.
I had a grinding noise before whenver I would turn the vehicle but over the weekend I flushed the PS fluid with new Pentosin Synthetic ATF (green can) and that fixed the grinding noises. HOwever, I still have weird thumping noises whenever starting from a stop or sometimes on reverse. Have had this problems for 5 years now....i figured it must be the rack or ps pump.
Old Aug 13, 2008 | 01:35 PM
Ligist's Avatar
well grinding or humming is when the ps is low, and from what i understand the rack is kind of like a big seal and shouldnt be causing a thumping....ive never heard anyone describe it as a thumping come to think of it lol so it might very well be the pump...sorry i couldnt have more insight
Old Aug 13, 2008 | 01:46 PM
thanks, I think I may try changing the PS pump down the road....so far I'm pleased that my ps flush took away the grinding noises....we'll see if it comes back.
mperugini2330
Jan 7, 2012 05:33 PM
bob martin
Jul 27, 2009 05:07 PM
Ultim8gamr
Feb 11, 2009 12:20 PM
