audi symphony
anyone know the best hidden eq settings for clarity on audi symphony radio?
RE: audi symphony
Follow the link in my signature to my registry page. There, I have a link to an article on this.
RE: audi symphony
have ur radio OFF ,press and holde TP button for few seconds, u should get screen 555555, u can change these numbers 0-9, they reflect front and rear speakers, low,mid and high tones but have no clue in what order, i found itr somewhere on the internet,look around, gl
RE: audi symphony
wrong key lolz :P but here is description with the correct one ;)
Hidden Equalizer The following is the procedure on how to access and adjust the "hidden" equalizer feature in the Audi Symphony radio. [ol][*]Turn off radio.[*]While pressing and holding the Preset 5 button, turn on radio.[*]You'll see a series of 8 digits displayed. From the factory, it's set to "55555555". You will not hear any sound when running in this mode.[*]The first four digits correspond to the four equalizer bands (low, low-mid, upper-mid, high) for the front speakers, and the last four digits are the same for the rear speakers. The level can be set from 1 (minimum) to 9 (maximum).[*]Turn the volume control knob to increase or decrease the level for the band (which is blinking). To advance to the next band, press the P.Scan button.[*]When you are done, turn off radio, then turn it back on to hear the results. On some versions of the Symphony, you must also cycle the ignition key to hear the results. [/ol] |
