Auxillary Fan Woes
Auxillary Fan Woes
OK...so my auxillary fan does not work at all...does not come on or anything...Where is the relay so that I can check it...
Also, what are some other things that I can check on to see what might be the problem?
RE: Auxillary Fan Woes
Well get the engine to operating temp, keep the a/c on so the switch sends power to the fan, then stick a sowing needle in the back of the connector on the fan and hook a voltmeter to the needle and check for voltage.
